Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
12 members (Guitplayer, Hotrod Lincoln, 32vsnake, Charles in CA, Peggy M, TUTS 59, 46 Texaco, Southerntruck, BC59, 3 invisible), 562 guests, and 1 robot.
Topics126,776
Posts1,039,271
Members48,100
Most Online2,175
Jul 21st, 2025
#778005 09/04/2011 3:53 PM
Want to install an inline fuel filter between pump and carb - what is the best type of "line to fitting" connection?
ODSS President
ODSS President
One that doesn't leak. Seriously, I've used hard line and flexible line. I like the hard line look better.
View here...
Top view.
That is one beautiful truck you have.
~ Cosmo
1949 Chevy Half Ton
I would look for a glass bowl filter that would mount to the carb, and run the steel line from the fuel pump into the filter. I think this would retain an original equipment look.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.122s Queries: 14 (0.118s) Memory: 0.6023 MB (Peak: 0.6431 MB) Data Comp: Zlib Server Time: 2025-09-22 15:59:17 UTC
Valid HTML 5 and Valid CSS
