0 members (), 106 guests, and 0 robots.
Topics128,101
Posts1,056,181
Members48,436
#77767 05/19/2007 2:34 AM
Junior Member
Junior Member
My 41 half ton shifter is stuck in second gear. The clutch works fine but I cannot pull the shifter out of 2nd gear. Does any one have an idea what would cause this?Thank you for your help.
#77768 05/19/2007 3:17 AM
If it's a "three on the tree", you'll have to pull on the shifter rod under the hood to nuetralize it. The shifter mechanism in the column is worn causing it to lock out the shifter in the cab,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#77769 05/19/2007 4:15 AM
Would a '41 pickup have a column shift? My first thought would be a three speed top loader with worn out forks that finally bit the dust. Did the truck work fine before then 'something happened' and it's stuck. Does this transmission have the reverse lockout lever. Would it be possible that this lever could be part of the problem.
Stuart
