7 members (Otto Skorzeny, UtahYork, Ponchogl, Lonnie, Bicounty, BC59, JW51),
160
Mod | | | Forums66 Topics128,089 Posts1,056,129 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77767 05/19/2007 2:34 AM | Joined: Dec 2006 Posts: 3 Junior Member | | Junior Member Joined: Dec 2006 Posts: 3 | My 41 half ton shifter is stuck in second gear. The clutch works fine but I cannot pull the shifter out of 2nd gear. Does any one have an idea what would cause this?Thank you for your help. | | |
#77768 05/19/2007 3:17 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If it's a "three on the tree", you'll have to pull on the shifter rod under the hood to nuetralize it. The shifter mechanism in the column is worn causing it to lock out the shifter in the cab, Scott | | |
#77769 05/19/2007 4:15 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Would a '41 pickup have a column shift? My first thought would be a three speed top loader with worn out forks that finally bit the dust. Did the truck work fine before then 'something happened' and it's stuck. Does this transmission have the reverse lockout lever. Would it be possible that this lever could be part of the problem.
Stuart | | |
