3 members (JoergK., 55shaker, BC59), 318 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
Apprentice
Apprentice
1 Offline
I have just replaced the head on a 292. Everything good except there is a drizzle of coolant oozing out at one of the head bolt caps. Why does this occur and what do I do to fix it?
If it's not a blind tapped hole, did you put the proper sealant on it? That would be the most likely cause.
Bill Burmeister
Apprentice
Apprentice
1 Offline
I do not know if the hole is blind, but I have to admit I did not use thread sealer. I have some Indian Head sealer on hand. Would that work?
The manuals suggest Permatex #2 sealer. That's what I use. You might check the bottle on the Indian head, it should say if it can be used on threads as a sealer.
Bill Burmeister
Now that it's "wet" with anti-freeze, you'll either have to drain it and dry out the hole with brake cleaner and compressed air or use a teflon tape or maybe pipe dope to seal it now,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
What is the location of the head bolt?
Apprentice
Apprentice
1 Offline
Leaking bolt is on driver side, in between # 4 and 5 exhaust valves.
I was thinking I should de-torque the head and remove all the bolts to add a thread sealer. It's just one leaking now, but this could happen with others, right?
Riding in the Passing Lane
All the bolt holes on the left side are wet. You will need to drain the block & clean the holes like Big trucks says. I would use high temp RTV. Give it an hour or 2 to set up before you put the coolant in.
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
1 Offline
OK, will do. Is there any chance this is due to some sort of head crack allowing water into the bolt shaft or is it pretty likely this is due to I did not use thread sealer?
If you can find a source for it, Permatex Super 300 brush-on gasket sealer would be an excellent choice. It's a little scarce, but it's much better than the standard #3 Permatex liquid. If you remove the head bolts one at a time, and re-torque them after applying the sealer, you shouldn't have to risk upsetting the head gasket seal. A 20 gauge shotgun brass brush and a little spray brake cleaner would be a good way to clean/dry the block threads before applying the sealer to the bolts. Drain the coolant to below the level of the top of the block, of course.
