4 members (Hotrod Lincoln, Guitplayer, TUTS 59, IHPWR), 185 guests, and 1 robot.
Topics128,108
Posts1,056,227
Members48,436
#777594 09/03/2011 3:47 AM
I was getting ready to start my engine tonight for the first time.
But after filling it up with coolant, I noticed a severe leak from the water pump! I think it must be leaking from the shaft. Maybe the seal dried up since it has been sitting dry for 30 years. I guess I need to replace the water pump.
I am pretty disappointed, I was excited to fire the engine up. Am I able to remove the fan and water pump without removing the rad?
Leo Offline
Moderator
Moderator
Disappointing, for sure. It depends on how much room there is between the fan and the rad. On my truck, (inline 6) I have to remove the rad.
Leo #777622 09/03/2011 4:50 AM
I just pulled the water pump out of my 52-3100 no need to pull the rad. just unbolt the pump with the fan on it and pull it out the top it will come right out no problem.
Pete
Thanks, it didn't occur to me to remove the fan + pump together. The rad would be a bit of a pain since it's half full of coolant.
Maybe I'll double check all the hose connections. But the leak is so bad I can't imagine it would be a loose hose. And it really seemed to be coming from the middle of the pump.
There is a weep hole in the bottom of the housing that drains when the seal is bad.
Cletis #777849 09/03/2011 10:07 PM
OK, I replaced the water pump (twice) after NAPA sold me the wrong part. Now I am fully aware of the difference between a short shaft 5/8 pump and a long shaft /16". I also took note of the weep hole never noticed that before!).
Anyhow, I am ready to start this engine up, wish me luck.
Stove #777873 09/03/2011 11:42 PM
luck
BC52 #777945 09/04/2011 4:16 AM
Would you believe it didn't start?
I fooled with it for a couple hours. It seemed to be getting spark. And I put fuel in the carb now and then. It even sputtered now and then. Maybe I should have replaced the head?
I'll check the compression tomorrow.
