| | | Forums66 Topics128,084 Posts1,056,085 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | I was getting ready to start my engine tonight for the first time.
But after filling it up with coolant, I noticed a severe leak from the water pump! I think it must be leaking from the shaft. Maybe the seal dried up since it has been sitting dry for 30 years. I guess I need to replace the water pump.
I am pretty disappointed, I was excited to fire the engine up. Am I able to remove the fan and water pump without removing the rad? | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Disappointing, for sure. It depends on how much room there is between the fan and the rad. On my truck, (inline 6) I have to remove the rad.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I just pulled the water pump out of my 52-3100 no need to pull the rad. just unbolt the pump with the fan on it and pull it out the top it will come right out no problem.
Pete | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Thanks, it didn't occur to me to remove the fan + pump together. The rad would be a bit of a pain since it's half full of coolant.
Maybe I'll double check all the hose connections. But the leak is so bad I can't imagine it would be a loose hose. And it really seemed to be coming from the middle of the pump. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There is a weep hole in the bottom of the housing that drains when the seal is bad. | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | OK, I replaced the water pump (twice) after NAPA sold me the wrong part. Now I am fully aware of the difference between a short shaft 5/8 pump and a long shaft /16". I also took note of the weep hole never noticed that before!).
Anyhow, I am ready to start this engine up, wish me luck. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Would you believe it didn't start?
I fooled with it for a couple hours. It seemed to be getting spark. And I put fuel in the carb now and then. It even sputtered now and then. Maybe I should have replaced the head?
I'll check the compression tomorrow. | | |
