2 members (NJC, 1 invisible),
109
Mod | | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 30 New Guy | | New Guy Joined: Dec 2009 Posts: 30 | I am installing a wood headliner in my 1952 1/2 ton panel truck. I thought I would post my progress. I am using pre-finished maple. I supported the headliner panel with 2x4's and added another board to create the arc I wanted, and then I attached bevel cut trim pieces to the edges to support the headliner. I then removed the temporary supports. I posted pictures at the following site https://picasaweb.google.com/barthhc/Headlinprog?authkey=Gv1sRgCMG2o5Hvxd-OpwE# | | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Hope to see more pictures as you progress. Ambitious project!! Ter | | | | | Joined: Dec 2009 Posts: 30 New Guy | | New Guy Joined: Dec 2009 Posts: 30 | The trim pieces supporting the headliner are now fastened. The section at the rear is now installed. The entire headliner is totally supported by resting on supports at the perimeter. It will not sag because it is bowed. I posted my progress at the following site https://picasaweb.google.com/barthhc/Headlinprog?authkey=Gv1sRgCMG2o5Hvxd-OpwE#A transition piece of moulding will be added where the 2 headliner sections meet at the back. The panelling over and to the rear of the front doors will be supported by the screws fastening the windlace. I am not sure how far I will extend the panelling down the sides. I am also considering adding lighting in the arched openings at the top of the sides. | | | | | Joined: Dec 2009 Posts: 30 New Guy | | New Guy Joined: Dec 2009 Posts: 30 | | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | Nice job there Harrybolt your timing is perfect, i have been running this over in my mind and was about to start doing the same thing. Did you try the paneling without the 2x4 in the center? I was thinking about screwing it right on to the steel supports.
layback
| | | | | Joined: Dec 2009 Posts: 30 New Guy | | New Guy Joined: Dec 2009 Posts: 30 | The panel is not attached to anything. It is just supported by beveled cut sticks along the sides and the metal over the windshield. The edges of the plywood sit on top of the supporting sticks. The plywood is bowed so it will not sag. The bow will change a little because the panel will expand and shrink as the temperature and humidity change. The plywood is a little below the 2X4 in the center. The 2X4 will restrict how far the roof will raise if some pushes up on the center. I was concerned if the plywood raised too far it might come off the side supports. Go thru the slides in the first link again. I have pictures and comments showing the process. | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | Had another look, got ya,
layback
| | | | | Joined: Dec 2009 Posts: 30 New Guy | | New Guy Joined: Dec 2009 Posts: 30 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | kewl looking. Plus it seems to "open it up" to where it looks bigger inside than it is. (now that you have practice come on up and do mine)  | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | That will look great, nice job. My only thought is that smooth wood will reflect sound and be kind of noisy, unless you have some good carpet. Keep the pics coming!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
