9 members (walterhvogel, Jay R, DadsFirstPickup, moparguy, JW51, Jon G, Gray_Ghost, Stovebolt48, 1 invisible), 59 guests, and 0 robots.
Topics128,079
Posts1,055,941
Members48,430
#77672 05/17/2007 3:37 PM
I'm replacing my 216 and 3-speed in my 51 1/2 ton, with a 235 and 3-speed transmission out of a 57 chevy. I want to retain the original column shifter. Do the stock shifter and linkages work with the later model tranmission and 235 out of the 57 chevy. I tried several searches on this subject, but couldn't find this exact question in the archives. Thanks
1949 Studebaker 2R16A
1961 Chevrolet Impala
1968 Chevrolet Corvette Roadster
1971 C10
#77673 05/17/2007 3:49 PM
3B Offline
Hy H.I., I think it should work okay, but you will probably have to use the shift arms from the original transmission, hope that helps.
#77674 05/17/2007 4:19 PM
H.I.
I had that setup in my '49 (column shift with '56 passenger transmission) and 3B gave you the right answer. I think you may have to file a new notch on the shift fork shaft to fit the arm(s) but it was pretty easy.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#77675 05/17/2007 6:09 PM
Thanks a lot guys, I appreciate it. I dig my column shifter.
1971 C10
#77676 05/17/2007 9:26 PM
I used a 235 and kept my original 3 speed in my 49.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
