| | | Forums66 Topics128,047 Posts1,055,622 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77672 05/17/2007 3:37 PM | Joined: Jun 2005 Posts: 37 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 37 | I'm replacing my 216 and 3-speed in my 51 1/2 ton, with a 235 and 3-speed transmission out of a 57 chevy. I want to retain the original column shifter. Do the stock shifter and linkages work with the later model tranmission and 235 out of the 57 chevy. I tried several searches on this subject, but couldn't find this exact question in the archives. Thanks
1949 Studebaker 2R16A 1961 Chevrolet Impala 1968 Chevrolet Corvette Roadster 1971 C10 | | |
#77673 05/17/2007 3:49 PM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy H.I., I think it should work okay, but you will probably have to use the shift arms from the original transmission, hope that helps. | | |
#77674 05/17/2007 4:19 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | H.I.
I had that setup in my '49 (column shift with '56 passenger transmission) and 3B gave you the right answer. I think you may have to file a new notch on the shift fork shaft to fit the arm(s) but it was pretty easy.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#77675 05/17/2007 6:09 PM | Joined: Jun 2005 Posts: 37 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 37 | Thanks a lot guys, I appreciate it. I dig my column shifter.
#77676 05/17/2007 9:26 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I used a 235 and kept my original 3 speed in my 49. | | |
