| | | Forums66 Topics128,078 Posts1,055,940 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 7 New Guy | | New Guy Joined: Aug 2011 Posts: 7 | I have under the rear of my truck a rearend i have no clue what it is,First it has a third member a housing and a perfectly round 10 bolt rear cover,open it up and you have two main caps that have a bolt in the middle that pushes down on the main bearings,then there is some kind of clutch pack behind the two vertical spider gears,i thought this was a 3/4 ton rearend but it has 6 bolt axels and they have not been redrilled,thanks for having me and any info appreciated. Shane
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Sounds like an Eaton HO33, which would be the original axle for a '61 1/2 ton. Having clutch packs in it also identifies it as being the rare factory Positraction variant, which was only made for 3 years. Gear ratio is most likely 3.90:1, though a 3.38 and 4.10 were also available.
Bill Burmeister | | | | | Joined: Aug 2011 Posts: 7 New Guy | | New Guy Joined: Aug 2011 Posts: 7 | Would you know where i might find more info on this rearend? Thanks shane | | | | | Joined: Aug 2011 Posts: 7 New Guy | | New Guy Joined: Aug 2011 Posts: 7 | did a lot of research last night on this eaton ho33 and that it is my rearend and found that yukon gear makes gears and axels for it and i can evan get the gears in a highway friendly 3.38 ratio, wooohooo, now that i know this i won't have to swap to a 700r4 ,wanna say thanks guys, first time out and you hit it out of the park, this forum rocks. Thanks Shane | | |
