1 members (Wooley),
105
0
Mod | | | Forums66 Topics128,151 Posts1,056,997 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 48 | Hi all I just bought a one ton 1954 3800 and where do I get tires and would you up grade to Radial tires Size is 700 x 18 Thanks! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | crockbuyer, you may want to ask that question in the BIG BOLT section but hang tight, a moderator may move it there for you?
Good catch on the 3800. I've been looking at a "bigger truck" myself. Anyone that answers could you please mention the price as well.
Good luck crockbuyer. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I believe if you switch to radials, you'll need to change wheels also. You probably have three piece wheels on the truck right now. If you do upgrade, I'd be interested in your old wheels.
Bruce | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I run 7.50x17 tires on my '48 3800. The radial 8.00x17 tires are 3" shorter which means your hiway RPM's will be higher and less top end speed. You mentioned 7.00x18 which were used on the dual rear wheel trucks with the "Bud" style wheels. Is that what you have? | | | | | Joined: Apr 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 48 | I have no idea I just am getting an idea of what I am getting in to! but it has evey option you could get! | | | | | Joined: Apr 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 48 | Thanks I have the same rims you have on your truck I may have to go with bias ply jst need to find where to buy them | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Did you buy the 3800 out of Iowa advertised as a 3 ton? If so it a nice truck.
Bruce | | | | | Joined: Nov 2008 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 65 | I bought some 19.5" wheels from Rickson and 8R19.5 Goodyears. It's overkill for my 3/4 Ton, but I like them, and they fit (barely). If you go this route, be prepared to spend some serious money. | | | | | Joined: Dec 2009 Posts: 4 New Guy | | New Guy Joined: Dec 2009 Posts: 4 | It is lots of fun trying find 7.00X 18 tires for my '54 1 ton with duals. It still has the original '54 tires, and although not worn, are now pretty cracked. I am going to do a body off restoration of my old truck, but need a rolling chassis so it can be moved around inside the barn, so I thought I might start with the wheels, and tires. I have done the front hubs, brakes, one at a time. The rear duals have not been off for a very long time, and I notice some rim bubbling of rust near the rivets. The lock rings seem OK, but I have never done a de-mounting of this type of tire and wheel before. I may defer that job to a guy who does that for a living since I have been told it is tricky. I am not planning a fancy restoration, but a plain, and solid one, exactly like you would find this truck in about 1960. Since it has the factory stake racks, I am copying them exactly, because the proportions are very handsome, and they work perfectly as a typical farm truck of the era. By the way, has anyone found a cheap way to ship heavy truck parts such as wheels, across the States? Is anyone coming up to Canada with a truck, or trailer, with some spare room? Cheers Warren | | | | | Joined: Apr 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 48 | yes 1500 dollars cash gettin brake job done so I can drive it Tony | | | | | Joined: Apr 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 48 | I bought tires at croker tires 188.00 each | | | | | Joined: Apr 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 48 | | | |
