0 members (), 68 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#77615 05/15/2007 1:07 PM
V
V Offline
I pulled the plugs on my 283 and one hole had water come out. (clear water) I know the eng. had antifreeze in it. There was a plastic bag over the carb. when I got the eng. I wonder if it may have gotten water down the carb. and one exhaust valve was open. Does this sound right? Tks. Virg :confused:
#77616 05/15/2007 1:22 PM
Where did the engine come from? Sounds like it got rained on or something. Does the engine turn over?
#77617 05/15/2007 6:46 PM
virg912iowa,
Water entering through an uncovered carburetor would have to go through a open intake valve to reach the cylinder. If this were the case, you would more than likely have several cylinders with water in them. I'm sure as you get into this engine more will be revealed.
Stuart
#77618 05/15/2007 10:28 PM
V
V Offline
I drained the oil and no water came out. Only one plug when pulled had water come out. Haven't tried to turn eng. over yet.
#77619 05/15/2007 11:13 PM
virg912iowa,
Things are looking up! Maybe some of the other cylinders are near BDC and actually have water in them, but pulling the plug hasn't opened the dam....what a optimist, right! Keep digging, you might have a winner in the old 283. smile
Stuart
#77620 05/16/2007 12:04 AM
virg,don't take chances.Pull the heads and have a look
#77621 05/16/2007 12:25 AM
Crusty Old Sarge
Crusty Old Sarge
I'm with Builder it sounds like it may have gotten wet. If the engine set up for awhile with the exhaust valve open it may have come in through there. I would see if the engine rolls over and check the other cylinders. You could pull the push rods out to close the valves and add compressed air to the cylinders, remove the thermostat housing and watch for air bubbles. If you see any it show a bad head gasket, if not than you may get lucky.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
#77622 05/16/2007 10:37 AM
pull the heads and clean it up or get the water out fast and oil it up crank it over with a starer for a while
