1 members (Hotrod Lincoln),
49
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77615 05/15/2007 1:07 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | I pulled the plugs on my 283 and one hole had water come out. (clear water) I know the eng. had antifreeze in it. There was a plastic bag over the carb. when I got the eng. I wonder if it may have gotten water down the carb. and one exhaust valve was open. Does this sound right? Tks. Virg :confused: | | |
#77616 05/15/2007 1:22 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Where did the engine come from? Sounds like it got rained on or something. Does the engine turn over? | | |
#77617 05/15/2007 6:46 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | virg912iowa,
Water entering through an uncovered carburetor would have to go through a open intake valve to reach the cylinder. If this were the case, you would more than likely have several cylinders with water in them. I'm sure as you get into this engine more will be revealed.
Stuart | | |
#77618 05/15/2007 10:28 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | I drained the oil and no water came out. Only one plug when pulled had water come out. Haven't tried to turn eng. over yet. | | |
#77619 05/15/2007 11:13 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | virg912iowa, Things are looking up! Maybe some of the other cylinders are near BDC and actually have water in them, but pulling the plug hasn't opened the dam....what a optimist, right! Keep digging, you might have a winner in the old 283. Stuart | | |
#77620 05/16/2007 12:04 AM | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | virg,don't take chances.Pull the heads and have a look | | |
#77621 05/16/2007 12:25 AM | Joined: Mar 2007 Posts: 3,372 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,372 | I'm with Builder it sounds like it may have gotten wet. If the engine set up for awhile with the exhaust valve open it may have come in through there. I would see if the engine rolls over and check the other cylinders. You could pull the push rods out to close the valves and add compressed air to the cylinders, remove the thermostat housing and watch for air bubbles. If you see any it show a bad head gasket, if not than you may get lucky.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | |
#77622 05/16/2007 10:37 AM | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | pull the heads and clean it up or get the water out fast and oil it up crank it over with a starer for a while | | |
