| | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Looks like some kind of electrical contacts, did it come out of the headlight buckets. I don't recall seeing anything like that in my 41, I'll look next time i'm at the shop. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2005 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 89 | Homer, Thank you for your response. Like you I think it is an electrical part. I think the part may have come off either inside or outside the firewall, floor and not the headlight buckets as I only have one. Lesson learned , take pictures !!!Refurbishing 101, take a lot of pictures!!! | | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | I have a 46 1/2 ton torn apart too. It does not look familiar. I did not take the heater apart. Maybe it goes inside the heater. 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | if it is 2 3/4" x 1 3/4" and 3/4" thick it is a clutch / brake pedal pad. Bolt under the floorboard to keep pedals from hitting metal to metal. Am I a winner? Cavebull | | | | | Joined: Mar 2005 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 89 | cavebull, Thank you as you were correct. I would not have figured it out as none of my pictures show the back side of the floorboard. | | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | I think those are the only tee nuts I have seen on this beast, the only reason it caught my attention. Glad I could help.
