3 members (55shaker, UtahYork, Hanks custodian), 79 guests, and 0 robots.
Topics128,048
Posts1,055,538
Members48,424
#775819 08/28/2011 7:50 PM
What is the attached? I took it off
my 46 1/2 and don't remember were it came from or what it is. I hope this works as it is the first time I have used Photobucket!!
http://s1198.photobucket.com/albums...46/?action=view&current=DSCF1126.jpg
Looks like some kind of electrical contacts, did it come out of the headlight buckets. I don't recall seeing anything like that in my 41, I'll look next time i'm at the shop. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Homer,
Thank you for your response. Like you I think it is an electrical part. I think the part may have come off either inside or outside the firewall, floor and not the headlight buckets as I only have one. Lesson learned , take pictures !!!Refurbishing 101, take a lot of pictures!!!
I have a 46 1/2 ton torn apart too. It does not look familiar. I did not take the heater apart. Maybe it goes inside the heater.
1946 Chevy Half Ton
('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS)
1976 Margay Panther X, MC91B
if it is 2 3/4" x 1 3/4" and 3/4" thick it is a clutch / brake pedal pad. Bolt under the floorboard to keep pedals from hitting metal to metal.
Am I a winner?
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
cavebull,
Thank you as you were correct.
I would not have figured it out as none of my pictures show the back side of the floorboard.
I think those are the only tee nuts I have seen on this beast, the only reason it caught my attention. Glad I could help.
cavebull
