Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Wayne67vert, 78buckshot, 1 invisible), 78 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#77580 05/14/2007 1:31 AM
Trying to install Langdon HEI on '54 261...can get the truck to idle, but will not pick up RPM's. Will buy a new timing light tomorrow (mine bit the dust)--does not backfire. Any suggestions?
Thanks,T.K.
#77581 05/14/2007 4:17 AM
Check the vac adv. Should be able to take the distr cap off and apply suction to the the vac adv and see the arm move. Another check is to gain RPMs very slowly using only the centrifugal advance, if that fails check to see if you can move the weights on the centrifugal advance.
Larry
I don't own a vehicle that isn't old enough to drink.
#77582 05/14/2007 8:51 PM
Riding in the Passing Lane
Sounds like the timing is way too slow. You might be a tooth off. Try turning the dist.counter clockwise & see if it perks up.
1972 Chevy c10 Cheyenne Super
