3 members (sssammm, Bill Hanlon, Otto Skorzeny), 40 guests, and 3 robots.
Topics128,035
Posts1,055,445
Members48,422
#773732 08/22/2011 12:40 AM
I have purchased a offey side plate for my 261 and it doesn't have the "provision" for the internal oil line. What can i do to make this work for my engine?
Not sure what you mean, my 261 has a offy type side cover, internal oil line not in the way. Possibly someone has modified that oil line on your motor.
If you could post a photo maybe I can see your problem.
1946 1/2-Ton Chevy
are you familar w/ the stock side plate that has the "bump" at top center? this is the provision i'm concerned with...i'll try to post a picture.
boomers59 #774606 08/24/2011 12:44 PM
I suggest:
1. Put a dab of paint/grease on the fitting that is causing the interference.
2. Bolt it on as best you can finger tight with equal gap all around.
3. Note the gap width as it is equal to the relief needed minus the gasket thickness.
4. Insure you have a bit of paint transfer and you know where to grind.
5. Use a die grinder to gently create a divot and repeat the process a few times until it sits flush. You should still have plenty of wall thickness left but compare the relief required to the overall part thickness before starting.
You Tube
Curt B. #774688 08/24/2011 6:23 PM
That's what I assumed he was talking about. The fitting behind that bulge stands proud of the block face by about 3/16" IIRC.
You Tube
Curt B. #774825 08/25/2011 3:35 AM
thanks for the info...this is on the "next" list of things to do. I've seen aftermarket side plates on engines but never thought about the fit, now i know!!
There is another choice to solve this problem.
Go to a good parts house that carries a supply of brass fittings or a good hardware store with same and check a 45 degree angle fitting that would attach to or screw into the block. The 45 degree angle will allow you to slightly bend the feed tube in toward the block and it will clear the sidecover. I did it with one of my Offenhauser sidecovers and it worked perfectly.
thanks Joe...i've got the 45 degree fitting on the list today(along w/ countless others) and i'm sure this will remedy the situation.
