4 members (Otto Skorzeny, klhansen, Shaffer's1950, Steelonsteel), 101 guests, and 2 robots.
Topics128,113
Posts1,056,618
Members48,450
I am installing a new 4 barrel and intake manifold. Got everything on but the carb linkage goes the oppisite way of the old carb. Can I just drill a hole in the top of the linkage so it will pull it or is there a better way? My truck is a 65 with the 283 v8.
thanks Brett
The Edelbrock Performer carb is a pull to open throttle.
My stock linkage worked fine on my 69, IIRC.
I guess I don't understand why you have a problem.
got pix?
regards,
Leon
Got it figured out Leon, thank you for answering. I was trying to connect the linkage to the bottom and it needs to go to the top of the linkage. I will have to drill out the hole at the top, it just fit so nice in the bottom hole.
Brett
