8 members (TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, msmall, Tyler Watts),
138
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | I pulled my old beaten up instrument panel and am restoring. I need to know which bulbs (oil, generator, temp, etc.) have one or two wires coming from the bulb socket. Secondly, I am assuming when the headlights are on, the panel will light with the single wire bulbs. Lastly, I have a light right under my fuel gauge. What does that represent? Does anyone have a picture of what the original panel looked like? Thanks!!!
Thom Masterson
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Do you have the dummy lights or the gauges? There were two types. | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 |
Thom Masterson
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | the little light under your fuel gauge (green) is a turn signal indicator. It blinks to show that the signals are on either left or right. You are correct about the instrument panel lights. They are the grey wires that are single. If the park lights or headlights are on the will come on. you can adjust strength of the lights by turning the dimmer switch (headlight switch) to the left or right. All the way to the left will turn the dome light on. I have a nice unit that came out of my 63, which is the same if you need a better cluster, minus the fuel guage. Just let me know. I can send pics if you need. Or you can do a wire conversion and swap in a set of the factory guages, which will give you a more accurate reading of the engine. | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Jon -
Thanks for the help. Cool truck too! Will the turn signal light be a 1 or 2 wire?
Thom Masterson
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Turn signal is two wires, 1 is dark blue and ill have to look the up tonight when I get home. Do you have the factory assembly manual? It has a complete set of the wiring diagrams...well worth the $30-$40 that the book sells for. It covers every area of the truck mechanically/electrically. | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | yes i have it. i looked through it but of course there is no rhyme or reason to what order they placed the pages in. i'll go through it again. thanks!
Thom Masterson
| | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Got most of my headlight switch together today. I am most proud of myself. Had to start laughing when the headlights, taillights and instrument panel lit up. Very Fun! Only one issue, my parking lights do not go on at all. This is a link to the switch I'm using... http://6066gmcguy.org/lighting/1960-light-switch.jpgAny ideas? I have new bulbs and wiring. Thanks!
Thom Masterson
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Have you checked the flasher? Might get the volmeter out and see if what your getting at the switch and the lights themselves.
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | sometimes the hood lights dont get a good ground because the hole is painted, i pulled mine and scraped the edge of the hole, | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Finally got the lights to work. DThela you were right...a bad ground. However, I used brand new sockets, brand new bulbs, everything is identical on each side. One side shines brighter than the other...significantly brighter. Is it the quality of my ground?
Thom Masterson
| | | | | Joined: Jan 2010 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 52 | If you have one light dimmer than the other then you most likely still have a ground issue. You have to clean all paint and oxidation from around the light socket holes in order to get a good ground. I have had to clean mine a couple of times since I've owned it. I finally ended up using an anti corrosive paste for electrical connections. I don't remember what it was called. I'm sure someone here knows. Any way it worked well and I didn't have to worry about it anymore.
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | get the paste at home depot. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | dielectric grease. most auto part stores have it.
