2 members (Guitplayer, MickeyP),
70
Mod | | | Forums66 Topics128,021 Posts1,055,356 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | I have a Unity spotlight model s6. Im trying to install it on my 57 Chevy 3100. Does anyone have a template? I already went to the Unity website and their kit is over 50 dollars which i'm not ready to pay. Any help is appreciated. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I have one of these on my truck. What type of template is needed? I just remember measure about how far up the pillar to drill and went for it.
Does the template help you with location and angle?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | I called unity customer service, and the E-mailed me a copy of the template for my truck.
John 50' chevy 3100 shortbed
| | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | The template does assure a proper fit. I just dont want to screw anything up. Il go ahead and contact customer service just like jhannigan said. Thanks for reply | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | There are a number of brackets that are used with Unity Spotlights there should be a number cast in the back side make sure that the one you have is correct for your model of truck (I have a box of a few new ones). This info used to be found on their site. But any of my calls to them I found them very helpful. Mike | | | | | Joined: Mar 2010 Posts: 78 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 78 | The 50 bucks gets you the proper bracket and drill bushing/guide and template and screws. well worth it IMO if it prevents drilling errant holes. also I needed a short shaft to eliminate interference with hood and or steering wheel.
1951 chevy 3100 short bed frame off resto.
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks for the link Woo, just spent the last hour and half downloading it to a Word file. Great information for anyone that is interested in servicing on of the spots. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well Lou sent me a copy of the template but I see now that who ever installed this spot not only drilled the hole crooked but they didn't have the correct bracket for an AD truck. Soooo, I ordered the correct bracket, bushing and template kit, two weeks ago. And according to the customer service guy, they are swamped with only two guys to handle that CS, tech lines and it sounds like a bunch of other tasks. Must be some sort of cost cutting deal or something. He couldn't tell me when my kit would be shipped or anything about it, says they aren't set up for that and he has to physically go out and check up on the order. Also says that sometimes it takes 4-6 weeks and that they had to order them so apparently they are having some of their parts made by outside vendors. Bottom line is, allow your self plenty of lead time when dealing with Unity. DG
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And it arrived today, only problem is the 125 installation kit is for a '61 Plymouth. It took so long to get the kit that I can't remember how I came up with that number or how I ordered it. I don’t think I talked with Unity because it’s hard to get anyone to answer the phone. And I haven’t been able to find any application data on their site. Looks like I’m going to have to get in the car and drive down to Chicago and stand toe to toe with someone down there.
DG
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Why not just buy the Plymouth?
Hahaha. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well your a big help Chris!!!
One of the boys sent me instructions to find the kit by make and year. So somewhere along the line the '1' got added to the kit number. It apparentllly should have been a '25'for the driver side '50, Chevy Pickup. DG
| | | | | Joined: Mar 2010 Posts: 78 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 78 | If memory serves me correctly it is # 50 I will check and if I am wrong I will post the correct #.Lou.
| | | | | Joined: Mar 2010 Posts: 78 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 78 | Ok thats what I get for trusting memory! the correct kit # is 25, just verified by looking at mine. Lou.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's what I thought I ordered, gonna try to get holt of them this morning and see if they have the 25kit in stock. If so I thing I'll take a drive down and exchange it, if they will. DG
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not sure exactly what goes on down at Unity Manufacturing but one thing for sure is not much customer service goes on. This whole thing started when I ordered a $77 bracket kit on 09/21/2011 and received the wrong one on 10/07/2011. Monday morning the 10th. I tried to get thru to Unity customer service and after leaving several recorded messages I finally got to talk to someone several hours later. The first guy transferred me to another customer service guy who heard my story and said he would get back to me. I waited till weeks end and on Friday I hadn't hear anything so I called again, took several hours to get past the recording and thru to a real person and once again the first guy passed me off to the second guy who was gonna get back to me. I waited another whole week and on Monday 17th. after getting a robotic answer till nearly noon finally got to talk to the first guy. The second guy that was taking care of this was off today but he would have him call me the next day. So here I am, another weeks passed by, it’s Friday the 21st., and nary a word from “Unity customer service”. Since I started on the truck about six years ago I’ve had a few really bad experiences with vendors but this company is beyond a shadow of a doubt the worst that I’ve had to deal with. So I guess at this stage I’ll have to take the day and drive down to the city and physically walk in to the office and try to get my $77 dollars back because it appears that there is no way I‘m gonna get an exchange. It’s gonna cost me dang near that much in time and gas to do that but now it’s gotten to be the principle of the thing.
They kind of got you over the barrel because there were so many of there lights out there and they are the only source for repair parts. I suppose that’s why they can be so poorly managed. When you compare the way they run their company to someone like McMaster who absolutely bends over backwards to give good service to even the smallest customer, the difference is simply night and day. Denny Graham Sandwich, IL
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | That's brutal Denny. I guess that's what happens to allot of big companies when they are the only game in town. They seem to get that "us vs. them" mentality when dealing with customers.
| | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | If you get your cash back, try putting an order for the bracket thru chevs of the 40's. I see they offer the unity left or right bracket kits and will now be ordering thru them since I have had great cust service with them in the past. | | |
