1 members (Charles in CA),
103
Mod | | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 57 | I have a 66 c20 which I put a refurbished 350 crate motor in. Not a performance motor, just a bone stock 4 bolt main 350 with dual exhaust and a quadrajet. My stock oil pressure gauge reads from 0-60psi. I have about 5000 miles on the motor. Since day one, the oil pressure when on the freeway or any mid range rpm is over 60psi. At idle it is about 30psi or higher. I broke the motor in with 10-30, did my first oil change with 10-30, and my recent and last oil change I switched to 5-30. Seemed to make it a bit lower at idle but just the same at higher speeds/rpm. My question is...is that normal? To me that seems way high. I'm not sure what the truck originally came with as far as the motor, so I thought maybe I have an oil pressure gauge suited for an inline 6? Any help would be appreciated. Thanks much. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I had a 260 ford that ran like that for 120,000 miles. I'm not sure if the two engines equate, but for what it's worth. | | | | | Joined: May 2009 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 57 | thanks. Yeah, I guess it's better than the other extreme which would be low oil pressure. My concern is that I don't want to damage the engine, blow oil by the valves or something along those lines. Not really sure how it could adversely affect the motor. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Have you ruled out the gauge? When I put a 350 in my AD, I replaced the gauge and it pegs out, cheap repop! | | | | | Joined: May 2009 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 57 | thanks for the reply. I guess it could be the gauge, not really sure. Are there different gauges for different motors or are they all the same? It is definitely the original gauge, but not the original motor. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | You don't say what kind of sender/gauge you have but if it's the newer total electric then I would look at making sure they are a matched pair. Different oil pressure senders vary output with the same amount of oil pressure. Case in point, my 350 motor runs, of all things, a Jeep sender due to my odd OEM (Packard) gauge. One size does not fit all. You can test your gauge with a variable resister and then hunt down the right sender. Good luck.
| | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I think newer engines run higher pressures. The V-6 in my '97 runs in the 50-60psi range at idle...It took me a while to get used to seeing that.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Feb 2004 Posts: 29,844 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,844 | Put a direct-reading gauge on it and confirm that your dash gauge is accurate. It's not uncommon for a small block Chevy to run those pressures, and it won't hurt a thing. It probably had a Melling high-volume pump installed when the engine was built, or some other high performance item. It's possible to put a lower-pressure relief spring in the pump, but the oil pan has to come off to do it. Other than consuming a tiny fraction more HP to drive the pump, there won't be any ill effects to more oil pressure. It definitely will not cause leaks or high oil consumption. Jerry
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Hotrod, please enlighten us 'grasshoppers', what is a "direct reading gauge"?
| | | | | Joined: Feb 2004 Posts: 29,844 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,844 | It's one that installs into the oil passage instead of a sending unit, and reads oil pressure through a flexible tube instead of sending an electrical signal. On a smallblock Chevy, the pressure port is right beside the distributor. I've discovered a bunch of inaccurate electric sending units, but they generally read too low, not higher than normal, or they are slow to indicate pressure changes.
One of my competitors on the dirt track put so many washers behind his oil pump relief spring that the load of turning the oil pump would stall the engine. When he got it started and floored the gas, the pressure split the side of the oil filter. He had the relief valve jammed down tight so there was no way to relieve excess pressure. Jerry
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I wish I had your problem. I'm almost zero when hot at Idle. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I wouldn't worry about your Oil pressure. I put a new Stewart Warner sender & gauge in my rebuilt 327. I get around 80 psi at start up running 10/30 Oil. After warm-up she idles between 20 & 30 psi. Running on the highway its usually around 60 | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | YOu have more than enough pressure but if its ever low I've always hear that as long as a chevy has at least 10lb per every 1000rpm's your good to go! ...just thought I'd throw this in  | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | 66 uses a direct reading gauge. I doubt they are accurately calibrated, esp after 45 yrs. Mine pegs when cold also, & my engine has many miles. I'd worry about something else. | | | | | Joined: Jul 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 89 | what oil pump is in it? hi flo/hi pressure????????
it ain't YOURS 'till it ain't stock!
1951 chevy 3100
