0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
....How do I tell which engine is in
my truck?I've searched,& searched....
- Doug
'60 Anglia
'67 MGB GT
'74 MG Midget
'78 B210
1960 Apache 30 Panel
By the casting number.
You'd probably have better luck posting it in the Engine Shop.
If its a 6 cyl. its most likely a 235 or 261
If its a v-8 its most likely a 283.
As Cletis said, check the casting#
Searching is easy once you know the secrets! First of all use the SEARCH at the top right of this page.
found this search
inliners numbers
1960 c10,20 and 30 used a 235 i6 and a 283 v8. this is in stk configuration. gmc used the 261 along with the 235 i6. canadian production gmc used a 283 v8 and us production used a 305 v6.
ron
Doug,
Assuming it is a 1960 Chevrolet?
And, assuming that padresag has ID-ed the possibilities.
If it is a 235/261, post the codes you find at the locations on this page. People will try to decode what you post.
