9 members (Woodcmiami, dt235sd, MickeyP, Gdads51, HandyAndy, k2handyman, chevy51truck, Otto Skorzeny, 1 invisible),
63
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 62 New Guy | | New Guy Joined: Aug 2011 Posts: 62 | I have been "stalking" this forum for about a week now after I got a "brand new" '57 Chevrolet 2 1/2 ton! It's s6 seems to be in pretty good condition, starts up first try. Just missing a battery, MC, and an abundance of road grime  juusssttttt kidding Can't wait to get to know you guys, and take part in your vast amounts of knowledge on this beautiful forum  Will be in the big bolt section pretty religiously throughout it's "re-freshening" Picture
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome Streamylc, looks like a good solid work truck you have. Don`t you have rust in NM? It's bad up here.
Leo | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Welcome to the Stovebolt from S.C. That truck has lots of possiblities. Its nice to know it has a good home......Keep us posted and let us know how we can help. | | | | | Joined: Aug 2011 Posts: 62 New Guy | | New Guy Joined: Aug 2011 Posts: 62 | Thanks guys!  I'm pretty happy with the condition I found the truck!! little to no rust in the areas that are the "biggest concern" that I've seen.... Only areas that I have worry about is inside the pillar support area (not sure it's proper name) on the passenger front side... and the upper column on the cab, that the vent window area of the door rests against (passenger side), that area I NEED to replace it's rotted pretty bad :-( other than that though everything should clean up "alright" :-) could be A LOT worse... our humidity here in the high desert is never too bad and the high temps zap it out even if it does get to 30%-ish. I'm already stocking up pics for questions ;-P This thing is TOO beautiful to let go down hill anymore
| | | | | Joined: Mar 2011 Posts: 164 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 164 | Awsome truck streamylc. I think you should make a wrecker out of it. Just me. Welcome to the bolt. There are lots of folks here to help you on your way.
Chris | | | | | Joined: Aug 2011 Posts: 62 New Guy | | New Guy Joined: Aug 2011 Posts: 62 | Awsome truck streamylc. I think you should make a wrecker out of it. Just me. Welcome to the bolt. There are lots of folks here to help you on your way.
Chris Thanks brotha  It maight eventually make it to a wrecker! ;-D but I have a custom iron business that is going to make well use outta it's flat bed, soooo it'd be a shame to put it outta commission (for now... If I'm not mistaken it's an original GM make... I saw another fellow here on the forum rebuild his that was just like it!
