Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (texas46, frogfarmer), 206 guests, and 1 robot.
Topics128,299
Posts1,058,705
Members48,493
#770371 08/10/2011 8:39 PM
I am redo-ing the brakes and tires on the ton/half...got all the brake parts from Altretta, thanks, Geoff...tires local...
I canNOT separate one of the front wheels from the brake drum...right you say, it is rusted together, just tap it with a sledge...did that, and ran the lugnuts back and tapped them...that drove the lugs out...set it up with bars under the rim and a tractor with a front end loader on the center of the drum and lifted the tires of the tractor off the ground...no go...I have multiple cans of penetrant oil, P.B. Blaster, auto tranny fluid, crow bars, breaker bars, 14 lbs sledge hits... I drilled large holes in the tires and used a welding torch to heat the rim...it will not separate. So, I'm looking for ideas from you shade tree guys...
thanks, Motoswiz
1948 Chevrolet 1.5-Ton Dually
More pix on Photobucket
Motoswiz
North Florida
I had to put sissor jacks (spare tire jacks) behind the wheel pushing against the spring stack. Loaded it as much as I dared and heated and heated until it let go, took a whuile but I won,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Update: I got it loose so I can go ahead and get the new tires mounted and the shoes to the re-liner...
Motoswiz
North Florida
How did you end up getting it off? Did you eat your spinach and do a Popeye, or did you try some nifty trick?
Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
