4 members (54farmtruck, klhansen, Rich'sToys, Southerntruck), 344 guests, and 3 robots.
Topics128,167
Posts1,057,096
Members48,463
Here is a spring to keep the door handle on my 1942 chevy truck from drooping. I need another one. Can anyone tell me a source?
Handle Spring
1942 Chevy 1/2-Ton Pickup
The Gallery story
Jeff's Blog
If this is correct it don't look like the one in your pic!
http://secure.oldchevytrucks.com/Door-Components-Handels-Brackets-Pins-Seals/products/168/
there is a pic of the door handle and look close you can see the spring. Actually I have one of those springs on my work bench!
It still may not solve your problem. Many times the square hole in the latch is worn or the stem on the handle. I've heard of guys heating them up and twisting them a bit and they they will stay up!!
Hope this is what you need.
Some owners of Chevrolets hate the idea of heating the door handle shaft and twisting it to solve the problem, but the real truth is that it is the only real good way to make sure it doesn't droop.
The spring is an "I hope it works." The heat and twist is a "That sure works great!"
I did it on my 37 and it does do the trick!
This spring does not go on the latch but on the long piece the latch attaches to. It goes on where the door handle attaches. I will attach a photo of the part later.
The Gallery story
Jeff's Blog
I took my latches apart and replaced the internal coil springs with longer ones. It helped a bunch but now the inside release is a bit harder to slide since the springs are tighter. The handles do stay up better. I didn't think of the heat and twist, but can see how it would work.
Joe
