1 members (Eileen), 271 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
#768212 08/03/2011 3:07 PM
Has any one seen a boot for the emergancy brake? My 59 had a plate about 6"x3" with a old rubber boot on the floor when I got it. I would like to keep the rats and hot air out when driving. I tried that rubber doughnut that is avail but saw no way to keep it inplace. and the rats ate it so now just a big air hole. Is there a better boot?
I
I Offline
This is the only thing I see available, Maybe try epoxying it in to keep it from falling out?
http://www.lmctruck.com/icatalog/ca/full.aspx?Page=70
Part #16
LMC Part # 30-1884
Ex Hall Monitor
Ex Hall Monitor
Maybe this?
Uses this to mount.
Tiny #768352 08/04/2011 12:16 AM
If you got rats nibblin' on stuff. Ain't nothing gonna stop that except killing the rats.
After the rats are dead, usually you would put a little door gasket adhesive to one side of the floor seal to get it to stay put.
Dave Baird
1951 Chevy 3803
Tiny, thanks for the link, I have that part in my "it didnt fit but to much to return box" it was too small the hole in the floor is 2" x 4" that part was 2x 3 oa. and the top of the boot was to small to let the lock release work. I need to figgure out how to post a pic, of what i have. maybe someone will recognise it. workin on the rat problem but they breed like rabbits.
Is it the foot brake or the hand brake?
Pete
Hi, I have that rubber boot, and slit the side at the top to make it fit and will use a larger piece of sheet metal with an oval hole in the middle to cover the whole hole and anchor the boot. A couple mothballs under the truck discourages critters.
Well, my time went so quickly,
I went lickety-splitly
Out to my ol' 55.
As I pulled away slowly,
Feelin' so holy,
God knows, I was feelin' alive..... Tom Waits, Ol' 55
this is the floor mounted break handle. or trans mission mounted. it moves a long way from release to park. i will try moth balls .
Ex Hall Monitor
Ex Hall Monitor
...I need to figgure out how to post a pic, of what i have.
<CLICK>
I bought this:
http://www.chevsofthe40s.com/detail/6646/Chevrolet_BOOT_FLOOR_HAND_BRAKE.html
It's smaller at the base than the original, so I am fabricating a new metal retainer based on the original retainer. The neck is a little tight on the lever, but it works. I've seen other boots for late-model shifters that I think would work too.
1959 Chevy 3/4-ton (pics posted soon)
I child-proofed my house, but my kids keep finding their way back in.
myold truck
OK here goes. This is the boot cover and plate i have hope this works. if not feel free to help tks tt
