2 members (Peggy M, Woodcmiami),
272
Mod | | | Forums66 Topics128,078 Posts1,056,057 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Has any one seen a boot for the emergancy brake? My 59 had a plate about 6"x3" with a old rubber boot on the floor when I got it. I would like to keep the rats and hot air out when driving. I tried that rubber doughnut that is avail but saw no way to keep it inplace. and the rats ate it so now just a big air hole. Is there a better boot? | | | | | Joined: Aug 2011 Posts: 20 New Guy | | New Guy Joined: Aug 2011 Posts: 20 | This is the only thing I see available, Maybe try epoxying it in to keep it from falling out? http://www.lmctruck.com/icatalog/ca/full.aspx?Page=70Part #16 LMC Part # 30-1884
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | If you got rats nibblin' on stuff. Ain't nothing gonna stop that except killing the rats.
After the rats are dead, usually you would put a little door gasket adhesive to one side of the floor seal to get it to stay put.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Tiny, thanks for the link, I have that part in my "it didnt fit but to much to return box" it was too small the hole in the floor is 2" x 4" that part was 2x 3 oa. and the top of the boot was to small to let the lock release work. I need to figgure out how to post a pic, of what i have. maybe someone will recognise it. workin on the rat problem but they breed like rabbits. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Is it the foot brake or the hand brake?
Pete | | | | | Joined: Oct 2006 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 99 | Hi, I have that rubber boot, and slit the side at the top to make it fit and will use a larger piece of sheet metal with an oval hole in the middle to cover the whole hole and anchor the boot. A couple mothballs under the truck discourages critters.
Well, my time went so quickly, I went lickety-splitly Out to my ol' 55. As I pulled away slowly, Feelin' so holy, God knows, I was feelin' alive..... Tom Waits, Ol' 55
| | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | this is the floor mounted break handle. or trans mission mounted. it moves a long way from release to park. i will try moth balls . | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | ...I need to figgure out how to post a pic, of what i have. <CLICK>
| | | | | Joined: Nov 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 78 | I bought this: http://www.chevsofthe40s.com/detail/6646/Chevrolet_BOOT_FLOOR_HAND_BRAKE.htmlIt's smaller at the base than the original, so I am fabricating a new metal retainer based on the original retainer. The neck is a little tight on the lever, but it works. I've seen other boots for late-model shifters that I think would work too. 1959 Chevy 3/4-ton (pics posted soon)
I child-proofed my house, but my kids keep finding their way back in. | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | myold truck OK here goes. This is the boot cover and plate i have hope this works. if not feel free to help tks tt
