| | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | I'm going to look at a '46 cab over (Yes, the bug has bitten hard) that is titled in another state. It would cut considerable frustration on my end if the truck is titled with the body numbers, not engine numbers, title number,etc. The gentleman that has the truck doesn't know what numbers are used on the title he has and doesn't sound able to go crawling around looking. Does anybody know where the body tag is? I also assume that the engine number is stamped into the distributor pad, is that correct? I've never messed with a Art Deco truck before. Thanks, Scott
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Jun 2011 Posts: 14 New Guy | | New Guy Joined: Jun 2011 Posts: 14 | | | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | Hey, thanks Jake. I've read through that about a dozen times and never caught that. So does anyone know where "Stamped on plate on rear of dash" is? Driver side, passenger side? I really didn't know that the dash had a rear. I would guess it's inside the cab at least, and it sounds like a stand on your head kind of deal. Scott
| | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | My 46 COE has a body tag on the passenger side of the cowl. The VIN doesn't match the tag,but the number on the tag tells the location and date of production if you go to vin buster on this site. Hope this helps. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Scott, is it a GMC or Chevy? That would answer some of your questions more clearly.
Jeff | | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | Sorry, it's a Chevrolet. Going to have a look tomorrow. It's about three hours away so I'm keeping my fingers crossed. Thanks, Scott
