2 members (moparguy, Napco Man), 124 guests, and 2 robots.
Topics128,049
Posts1,055,680
#767304 08/01/2011 1:30 AM
Earlier today my truck stalled, I discovered that there was no gas getting to the carb. Took apart the fuel pump and found that one of the check valve diaphragms was unseated. Put it back together and it ran. Took off again and now and hour later I'm on the side of the road. Took it apart again, check valve is in place, put it back together and nothin. Any ideas? I'm stuck here with nothin but a screwdriver! (235 engine, 61 C10)
Do you have fuel coming into the fuel pump? You might have stuff coming from the tank causing problems. If you have fuel coming into the pump and its not pumping that is the problem. If you take the pump off and work the arm in and out you should be able to see if its working. Has the truck been driven regularly or has it been sitting?
I had an almost new pump and the diaphragm went bad after a couple years. i think because of the ethanol in fuel. i put an electric pump on as a back up.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Thanks guys, yeah the truck was sitting for 8 years until a month ago. When I got the fuel pump apart again I saw some small debris inside. I think it was causing the check valves not to seat. Gas comes in but it didnt pump out. I got it to start up and run home. When I got the truck a month ago I pumped the old gas out of the tank, but I didnt take the tank out and drain it and clean it properly. I ned to do that and install an inline fuel filter.
