| | | Forums66 Topics128,093 Posts1,056,477 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 257 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 257 | Hi. I am a new to the forum, just bought a '59 Apache and I have a question. I would like to replace the front axle, leaf spring assy on my truck. I have the opportunity to buy a complete drum to drum front axle assy off of a '57 truck. Is this front axle assembly compatible with my '59 Apache truck. The reason why I want to swap these out is because the previous owners did a complete hack job in trying to lower the front. They flipped the axle and also removed what looks like one of the leaf springs from each side. The axle assembly I ant to buy is complete and it would bring the front up to stock height. Thanks for your time | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | welcome to the garage guy, have a look around here and you'll learn a lot about your truck - the 55-2nd to 59 axles are the same .... if you don't have manuals, you'll find the 55.2 shop manual and the 59 supplement hereBill | | | | | Joined: Jul 2011 Posts: 257 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 257 | Thanks for the response squeeze. I bought that front axle/leaf spring assembly today, thanks for your advice. | | | | | Joined: Feb 2005 Posts: 36 New Guy | | New Guy Joined: Feb 2005 Posts: 36 | Thanks for the response squeeze. I bought that front axle/leaf spring assembly today, thanks for your advice. I'd check the parts on the new one before installing. Check the kingpins, brakes, springs. Easier to fix it off the truck. | | | | | Joined: Jul 2011 Posts: 257 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 257 | [/quote]I'd check the parts on the new one before installing. Check the kingpins, brakes, springs. Easier to fix it off the truck. [/quote]
Hi, thanks for the advice. Everything looks good on the replacement and it's already been swapped out. | | |
