4 members (Wayne67vert, Southerntruck, Guitplayer, Napco Man), 106 guests, and 2 robots.
Topics128,093
Posts1,056,477
Members48,444
Hi. I am a new to the forum, just bought a '59 Apache and I have a question. I would like to replace the front axle, leaf spring assy on my truck. I have the opportunity to buy a complete drum to drum front axle assy off of a '57 truck. Is this front axle assembly compatible with my '59 Apache truck. The reason why I want to swap these out is because the previous owners did a complete hack job in trying to lower the front. They flipped the axle and also removed what looks like one of the leaf springs from each side. The axle assembly I ant to buy is complete and it would bring the front up to stock height. Thanks for your time
welcome to the garage guy, have a look around here and you'll learn a lot about your truck - the 55-2nd to 59 axles are the same .... if you don't have manuals, you'll find the 55.2 shop manual and the 59 supplement here
Thanks for the response squeeze. I bought that front axle/leaf spring assembly today, thanks for your advice.
rue Offline
I'd check the parts on the new one before installing. Check the kingpins, brakes, springs. Easier to fix it off the truck.
[/quote]I'd check the parts on the new one before installing. Check the kingpins, brakes, springs. Easier to fix it off the truck. [/quote]
Hi, thanks for the advice. Everything looks good on the replacement and it's already been swapped out.
