11 members (David Bush, msmall, Southerntruck, Tyler Watts, Hush, JW51, Hotrod Lincoln, jasrking, Joe H, Gray_Ghost, Forty9),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Thanks for the Heads up Cletis... Ordered. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | That is a good price. I think I paid about $50 for mine five years ago. A very handy tool!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | $44.69 with shipping...to my pad. Good buy. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Thanks for the tip Charlie. I have one somewhere, but you have seen my place. I can't always find things when I need them. I could have used one yesterday. A relay started heating, and I had to find the weak connection with my finger. So needless to say, I ordered another one. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Never felt the need for one of them bad enough to pay the price. But that's even cheaper by nearly ten bucks than the one Harbor Freight sells. So Charlie, since I don't have one and a man has to have one of everything, I dun let ya talk me into ordering one. I did a series of tests pertaining to the percolation problems with the Stovebolt’s a few years back. I was trying to isolate the hesitation that is do common with these engines. I used an Omega digital temperature monitor with a thermocouple. That has a very slow response time. That infrared unit would have been a better choice because of the response time, if it's accurate that is. The more I think about it the more uses I can see for one. When I was into the airplanes, since they were air cooled we used the cylinder head temperature to monitor the performance of the engine. It would be interesting to see what the different temps are around the Stovebolt also. Such as different points on the block, head, intake and exhaust. Would come in handy if you were having vapor lock problems with your hot rod.
Tool Topia has some really good prices. Much of what they sell is drop shipped from another vendor or directly from the manufacturer. I bought a couple of KD valve spring compressors from them a few months ago. The small one was in a blister pack and was missing one set of jaws. Took four phone calls and about a month and a half to get it rectified. Reason being that, although they listed the tool in their catalog they are not a KD dealer, so they had to order it from a KD dealer who had to order it from the KD factory. I gotta say though, the girls on the phone were very sympathetic and as helpful as they could be and we finally got it straight. And if you need a few more trinkets for your tool box and can scrape together enough for a $100 order the shipping is nixed. That’s what I did this time for the temp monitor.
DG
Denny G Sandwich, IL
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you're funny Denny  spend another 60 bucks to save the $6 shipping on an item that would be 60$ more elsewhere for accuracy, the important part isn't the unit, but the operator - notice that one of the specs is the "DS ratio", Distance to Spot, which is most commonly 12:1, meaning at a distance of 12" you're measuring the blackbody radiation over a spot of 1" diameter, so the further away you are the larger the area of measurement and the more likely there will be some 'spill over' from surrounding radiation - that behavior is the reason for the laser beam, aiming accuracy to localize spot measurements .... beyond that, and aside from manufacturing defects, the accuracy is as good as the math and physics that it's based on, they're all pretty much the same ... although because of my food processing business, I paid the price for a 3M unit that still meets scientific standards years later - no telling about the Chinese knock-offs  an interesting experiment with this type of non-contact radiation thermometer: point it up, the 'clear sky' temperature is the temperature of the bottom of the stratosphere, cloud temperatures show their reflectivity depending on density .... the "greenhouse effect" | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah, I'm a real piece of work all right Squeezer. But I did need the other tools that I ordered, cuz I didn't have them in the box either...
Got that stuff to day from Toll Topia, meter seems to work as it should, I walked aroiund shooting everything I could find with it and the temps seemed logical. Cept when I took a shot in the back of my mouth and it said I was down to 97.6°.
Denny G
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Yeah,
Denny G That's fast shipping Looks like the price jumpped up. $32.00 price is labeled sold out. It's now $37.00 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I got an email from Tooltopia today saying that mine is back ordered for 2 weeks or more. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Boy, half of us Stovebolters must have made a run on Tool Topia for those thermometers based on Charlies tip, let see, that'd be about 12 thousand of us right?? No wonder they sold out..
Found a new use for it last night. My "big old wife" called me in for supper and I shot the goulash. I told her "anything under 130.5°F and she would have to warm it back up while went back out and finished what I was doing in the garage." DG
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...and HER response was.................. LOL I did something similar once and I heard the garbage disposal going whrrrrrr as I went out the door  | | | | | Joined: Nov 2008 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 104 | If your engine has a miss, you can instantly tell which cylinder by checking the header temps of each cylinder. The cylinder thats not firing will have a lot lower temperature. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The Harbor Freight CEN-TECH brand linked above will be going on sale for $27.99 if you purchase it on line, when you check out enter coupon code 39845060 it will drop the price. Limit 4 I get the H.F. mailer  it was listed in todays mail. I did recieve my tool-topia mastercool infrared thermometer today Thanks | | |
