3 members (66flea, 1955 1 Series, Shaffer's1950), 352 guests, and 3 robots.
Topics128,154
Posts1,057,014
Members48,460
Which gasket set should I use if I am going to be using a 216 intake and exhaust on my 235 motor?
I already have the adapter rings/sleeves for the intake I am just not sure if I should get a set of 235 gaskets or 216 gaskets.
Charlie
I could be wrong, but I think they are cut the same even though there is an intake port size difference. But,I would opt for a 235 set though to play it safe.
Drew
Why are you using a 216 I/E manifold set on a 235?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Because I don't want to deal with the exhaust issue with the 235 setup and I want to use the horn mount that the 216 has. I eventually want to put fenton exhaust and a different intake but this will get me back on the road.
I used the 235 gasket on my 235 with 216 manifold.
I didn't use any sleeves
If you need the gasket for the heat riser (between intake/exhaust)you will need the 216 gasket.
Good luck
so the sleeves were not necessary?
Oh well, thanks for the info!!
Charlie
P Online: Content
I would use the sleeves and the 216 gaskets.
You can use 235 gaskets but you need to be careful to line them up with the ports exactly, or you could have leaks do to there larger openings.
My Blog
I don't know if they are necessary. When I removed the manifold it didn't have any rings
So I put it back together with out them.
Later I found out here in the forum that step-down rings are available.
Also learned here that pre 54 235 manifolds will have the bracket for the horn
If I had the step down rings I would of used them
Good luck
