0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 32 New Guy | | New Guy Joined: Jan 2011 Posts: 32 | I am having difficulties keeping my '53 235 running. I have re-built the carb, replaced inline fuel filters, and tested the fuel pump. Everything appears to be fine. The only way she'll start is to but gas down the carb to prime it. Once started, runs good at idle. Once on the road, makes it about 2 blocks and dies. Re-prime, and another 2 blocks. I am stumped. Any ideas to what I did wrong?
1949 1.5 Ton 4400, 1969 c10, 1989 c1500, 1990 K2500, 2010 C1500 Crew
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Check the rubber sections of the fuel line. Could be there is a small hole in the line. Also pull the float assy out of the tank and see if the sock inside the tank is okay, | | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | I had a similar problem with a 216 engine. When searching online, someone stated that a leaking intake manifold gasket could cause this problem. Good luck. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | When it dies, pull the gas cap quickly. If you get a big sucking noise, you've got a plugged vent line to the tank. I had a similar problem on a 47 Mercury about 45 years ago, and it turned out to be a big grasshopper wedged into the pickup line inside the fuel tank. The car would run about a mile, then stall and refuse to restsart for 30 minutes or so. Jerry
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I'd be curious if your carb was running dry too. I know you said you rebuilt the carb, but it you blow into the gas line going to the carb and your ears POP and then check to find the bowl empty... A sticking float is your culprit. Happened to me at least once... ha. Hope the issue turns out to be a minor fix for you. Good luck. Jerry Wilson | | | | | Joined: Jan 2011 Posts: 32 New Guy | | New Guy Joined: Jan 2011 Posts: 32 | thanks guys. I will try all of these and keep digging. Love this old iron, but sometimes can be a pain to find the smallest problems. At least I know it's not a computer, LOL!
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Be sure to reply back with your findings.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | On my 235 (54) it was the fuel pump that was causing this issue. I had the factory style (no bowl/non-vacuum assist). It would test fine and then quit later, I went with a very reasonable $20 eBay electric pump and have not had a problem since. My truck did exactly the same things you describe the new pump fixed it. | | | | | Joined: Jan 2011 Posts: 32 New Guy | | New Guy Joined: Jan 2011 Posts: 32 | Well, when I bought the truck, I was told that the fuel system had been gone through and the tank had been re-done. Guess what, NOT. I disconnected the fuel line off the peckcock and there was nothing comming out. Figured there had to be some sludge in the tank or the valve was bad. There had to be 30 lbs of rust and gunk in the tank. I have ordered a new one and a new sending unit from Classic Parts. Gonna give this a try and then see if the fuel pump still needs help. I feel like such a fool. Sorry guys. I will let you know what happens when I replace the fuel tank and peckcock.
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | eggo, we've all been there. Some of that crud may have have lodged in or damaged your fuel pump. But you'll know soon enough. And I'm sure you'll replace those filters, 'cause you know what they're full of!!!! Good luck.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Good advice about where else it may have traveled. Replaced my gas tank after finding it full of rusty gunk. The rest of the rusty gunk was in the fuel pump and carb even with a good fuel filter. | | | | | Joined: Jan 2011 Posts: 32 New Guy | | New Guy Joined: Jan 2011 Posts: 32 | Hey guys. Finally got home and installed the new tank. She purrs like a kitten now! Got fuel, got air, got spark, got brakes, I now have a working stovebolt! Will have to post pics of progress/rebuild on the gallery site. Thanks everyone for all your help.
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | Big Tee, That is not an uncommon occurance either. I see a lot of older cars regardless of make suffer from blocked fuel passage due to filters being plugged by the sediment in the fuel tank. Hopefully others will see this and check the sediment situation in their fuel tanks too. Normbc9 | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | I understand your pain. Had to install a new fuel tank myself. Rust was filling up my filters in just a few. I had to put new line, pump and carb on mine. Waited to long to install a tank. Good to hear you got it going. | | | | | Joined: Oct 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 67 | sounds to me like the fuel pump may have the pressure but not the volume it needs, hence it can keep up at idle but not driving it. | | | | | Joined: Jan 2011 Posts: 32 New Guy | | New Guy Joined: Jan 2011 Posts: 32 | Well guys, sorry for the delay, but finally got back to the Big Bolt the other day. Found out after replacing the fuel system from tank to engine, dang thing still didn't run right under a load. Would only idle. So I took the carb apart again, nothing noticeable. Went online to see about another carb kit, and long behold, the Rochester BC has 2 kits available on the Napa site. Napa database only shows one, but Napa online showed two. They were the only ones who had the correct one. Ordered the other kit, put it in, and now runs like a top. Can't believe it. Starts without pumping and everything. Thanks for all the input and help everyone.
