| | | Forums66 Topics128,094 Posts1,056,489 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 13 New Guy | | New Guy Joined: Sep 2010 Posts: 13 | I have a 65 chevy pickup with a 68 250 engine when i try to wire it up it will only run while cranking? If i add a key on wire it will start & run but when you turn the key off the bendix grinds? I got something wrong no colors on any wires. If any one can help me out I would be thankful. Jerry | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | I re-wired my 62. Sometimes when I turn off the truck I hear a grinding noise as well. What is that? Is that a bendix? If so, what's a bendix and how do I fix that grinding noise?
Thom Masterson
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The Bendix is part of the starter motor solenoid which should disengage once the engine has started.
Drew
| | | | | Joined: Nov 2010 Posts: 14 New Guy | | New Guy Joined: Nov 2010 Posts: 14 | | | |
