3 members (rfs56trk, Danielbolt, FAST55), 77 guests, and 3 robots.
Topics128,094
Posts1,056,487
Members48,444
#763354 07/18/2011 12:38 AM
I have a 65 chevy pickup with a 68 250 engine when i try to wire it up it will only run while cranking? If i add a key on wire it will start & run but when you turn the key off the bendix grinds? I got something wrong no colors on any wires. If any one can help me out I would be thankful. Jerry
I re-wired my 62. Sometimes when I turn off the truck I hear a grinding noise as well. What is that? Is that a bendix? If so, what's a bendix and how do I fix that grinding noise?
Thom Masterson
The Bendix is part of the starter motor solenoid which should disengage once the engine has started.
Drew
