1 members (Eisenholtz), 59 guests, and 3 robots.
Topics128,022
Posts1,055,377
Members48,422
#764117 07/20/2011 6:18 PM
SPL
Offline
Replacing my 1956, 235 gear and I need to know what is best to put back. I know there is aluminum and fiber faced and this will only be a weekend pickup driver.
SPL #764119 07/20/2011 6:29 PM
Fibre gears are quiter but aluminum is stronger. How long did they original fibre gear last? For an occasional driver you might be happier with a fibre gear. Absolutley nothing wrong with them.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
SPL #764121 07/20/2011 6:30 PM
The aluminum gear is correct for a truck engine (at least on '55 and up). I'm unsure if the fiber one is still available new, but it will have a somewhat quieter operation.
Bill Burmeister
LONGBOX55 #764146 07/20/2011 8:23 PM
I always thought the fiber gear was quieter also, but if you take the time to put a dial indicator on an alum gear, when installing, and make sure it is running straight, they are also quiet.
My Blog
Pre '68 Dave #764221 07/21/2011 1:14 AM
Yep still out there Bill, just got my 216 back last winter from the engine shop and they used a fiber gear as I asked them to.
My '54, 235 has an aluminum gear and I didn't notice any excessive noise with it. According to the original owner of the truck the engine had never been apart.
DG
Denny G
Sandwich, IL
Denny Graham #764231 07/21/2011 1:51 AM
I wasn't 100% sure on the fiber gear, Denny. I knew the aluminum one was, as I had mine replaced when the new cam was put in. I'll admit, I never really noticed any difference in noise in any of the 235s or 216s that I've tinkered with.
Bill Burmeister
