0 members (),
78
12
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 27 New Guy | | New Guy Joined: Apr 2010 Posts: 27 | Replacing my 1956, 235 gear and I need to know what is best to put back. I know there is aluminum and fiber faced and this will only be a weekend pickup driver. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Fibre gears are quiter but aluminum is stronger. How long did they original fibre gear last? For an occasional driver you might be happier with a fibre gear. Absolutley nothing wrong with them. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The aluminum gear is correct for a truck engine (at least on '55 and up). I'm unsure if the fiber one is still available new, but it will have a somewhat quieter operation.
Bill Burmeister | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I always thought the fiber gear was quieter also, but if you take the time to put a dial indicator on an alum gear, when installing, and make sure it is running straight, they are also quiet.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep still out there Bill, just got my 216 back last winter from the engine shop and they used a fiber gear as I asked them to. My '54, 235 has an aluminum gear and I didn't notice any excessive noise with it. According to the original owner of the truck the engine had never been apart. DG
Denny G Sandwich, IL
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I wasn't 100% sure on the fiber gear, Denny. I knew the aluminum one was, as I had mine replaced when the new cam was put in. I'll admit, I never really noticed any difference in noise in any of the 235s or 216s that I've tinkered with.
