| | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76363 04/16/2007 7:14 AM | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | I put gear oil in the transmission yesterday on my '53. I had changed the gasket on the side of the tranny several years ago when I started this restoration. This morning I found it leaks around that gasket. I thought these were supposed to be installed dry and with no permatex. Guess that's not the case. Assuming the gasket doesn't tear when I take the side plate off, can it be reused once it is saturated in oil if I permatex it, or will it require a new one? | | |
#76364 04/16/2007 11:48 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | If your speaking of the PTO gasket the originals were cork and were installed dry. Check your cover plate to make sure it is flat ans use star washers on the bolts. No sealeant should be required. | | |
#76365 04/16/2007 5:04 PM | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | It is just forward of the speedometer gear and takes about 5 bolts if I remember right. The gasket they sent me wasn't cork. It was more like cardboard. I'll check it out again. Thanks. | | |
#76366 04/16/2007 7:03 PM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | make sure the bolts arent to long and it didnt get the cover tight>? theyre not that hard to seal, put some silicone (sparingly) on the old gasket and reuse it...
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#76367 04/17/2007 5:25 AM | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | You know, one of the problems with getting older is being forgetful. I took the cover off where the leak was happening and it was immediately obvious that I had never changed the gasket. So I made a new gasket, used a little Permatex 2A and put it back on. Will let it set over night and then put gear fluid in tomorrow night. It will probably fix the problem. Harbor Freight has those hole punch sets and say what you will about HF, these punches are fine. Third time I've used them. The whole set was no more than $5 and they work great for cutting out gasket bolt holes. | | |
