2 members (Otto Skorzeny, 1 invisible), 136 guests, and 1 robot.
Topics128,109
Posts1,056,266
Members48,439
#76363 04/16/2007 7:14 AM
I put gear oil in the transmission yesterday on my '53. I had changed the gasket on the side of the tranny several years ago when I started this restoration. This morning I found it leaks around that gasket. I thought these were supposed to be installed dry and with no permatex. Guess that's not the case. Assuming the gasket doesn't tear when I take the side plate off, can it be reused once it is saturated in oil if I permatex it, or will it require a new one?
#76364 04/16/2007 11:48 AM
If your speaking of the PTO gasket the originals were cork and were installed dry. Check your cover plate to make sure it is flat ans use star washers on the bolts. No sealeant should be required.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#76365 04/16/2007 5:04 PM
It is just forward of the speedometer gear and takes about 5 bolts if I remember right. The gasket they sent me wasn't cork. It was more like cardboard. I'll check it out again. Thanks.
#76366 04/16/2007 7:03 PM
make sure the bolts arent to long and it didnt get the cover tight>? theyre not that hard to seal, put some silicone (sparingly) on the old gasket and reuse it...
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#76367 04/17/2007 5:25 AM
You know, one of the problems with getting older is being forgetful. I took the cover off where the leak was happening and it was immediately obvious that I had never changed the gasket. So I made a new gasket, used a little Permatex 2A and put it back on. Will let it set over night and then put gear fluid in tomorrow night. It will probably fix the problem. Harbor Freight has those hole punch sets and say what you will about HF, these punches are fine. Third time I've used them. The whole set was no more than $5 and they work great for cutting out gasket bolt holes.
