1 members (ronsway), 185 guests, and 2 robots.
Topics128,167
Posts1,057,019
Members48,458
#755792 06/19/2011 3:37 PM
I hear some of the early one's had issues.
1937 Chevy 1/2 ton panel
The preferred one is from 87-92. 93's are 4L60E (electronic)
Fred
I prefer to have any trans gone thru by a friend of mine who builds transmissions for towing/racing/etc. Cheep insurance
88 and newer have electronic speedos
Got mine from Bowtie overdrives . Just didn't want to take my chances on a used non overhauled one. Just love it, not a single problem with it, just drive and drive!! thumbs_up
She's one 55 year old with a spare tire that looks good!
It's not rocket surgery. . . .
http://www.picturetrail.com/fredoly
http://www.cardomain.com/ride/2412127
I took out my 350 automatic. I'm running 400 horses. I put in a 700r4 and man, I've never been happier. First gear is lower and with a shift kit its been a killer...... so much so that just TONIGHT the rear end gave up the ghost. I shelled it and drifted into the yard! The shift kit has to go!!
These guys build transmissions for studs. They will ship.
http://www.phoenixtrans.com/
~Jim
You're learning about shift kits the hard way. If you simply shift up, never down, a shift kit is OK, I guess, but on several of the downshifts possible during normal driving, the shift timing is such that you're in two gears at once, momentarily. That locks up the rear end for a fraction of a second, and either breaks the spider gear pivot shaft, or wears out the carrier housing. I've seen carriers with the pivot shaft hole worn into a slot 1/4" long as a direct result of a shift kit being installed. There are better ways to beef up a transmission that don't involve screwing around with shift timing, but I'm sure all the self-appointed experts here will disagree with me.
How do you address the electronic speedo with a stock gauge?
convert to mechanical speedo drive
50 chevy 3100
get the electric speedometer drive for $300 (cable X - from Abbott industries) or replace the stock gauge and buy an electronic speedo for about $100
you dont need to spend $300 or even $100 to do this. oem parts are availiable if you look. use the mechanical speedo drive for an older 700r4 in the newer one. thats what i did when i put in a 1990 700r4 into my 1983 monte carlo
50 chevy 3100
