5 members (Bill Hanlon, Gdads51, 50Chevy3100, Charles in CA, 1 invisible), 59 guests, and 6 robots.
Topics128,095
Posts1,056,078
Members48,433
#762671 07/15/2011 6:04 AM
F Online: Content
Like many others, I use a "Battery Butler" on my 6V battery to maintain the charge and it is getting the job done, but one never knows...! Am I missing something, or is there a lack of available portable 6V jump starting units in the American market? If this is the case, what is recommended for jump-starting a dead 6V battery--with another 6V battery only? That is not always practical in the field/on the road. Should one stay away from using a 12V to jump start? Any advice is appreciated. Thanks.
I saw a program where a guy had his Packard hooked to a 12v jump box for a strong starting but run the rest of the system on 6v.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
some suggest turning off all the lights, radio and accessories. In addition, though, pull off one lead from the 6V battery terminal and connect the jumper to the free lead. This eliminates the danger of battery explosion when current surges into the 6V battery.
Once the jumper is connected, turn on the ignition and quickly crank the car until it starts. Do not delay or the 12 V could damage the instruments. As soon as the engine starts, disconnect the jumper and jam the lead back onto the 6V battery terminal. If you're lucky, the engine will keep running through this transition (keep the revs up so it will run on the generator during brief time the battery lead is not connected) and you'll be on your way.
or you could just push it a few feet and pop the clutch
Redryder pix
My Hotrod
I've used 12v. to jump in the past w/o any ill effects.
1946 1/2-Ton Chevy
I've read a few articles on the subject, and most people have gotten safely away with using a 12V to jump. The best method I've read about it is grounding (using correct polarity) to the frame, and touching the 12V lead directly to the starter connection in the engine bay. Don't spend too long sending 12V through a 6V system as something will eventually smoke.
Dave Baird
1951 Chevy 3803
They do make portable 6 volt jump starting units, I have one. You can charge it with a 12 volt via the lighter socket or 110 AC.
Now Ron, come on, don't dangle that carrot in front of us as if you were trying to lure us into a cage! Complete your reply and tell us what the Make & Model of that jumper unit is that you have and maybe when and when you got it if you recall it.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
