8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert),
94
Mod | | | Forums66 Topics128,052 Posts1,055,716 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 21 New Guy | | New Guy Joined: Jul 2009 Posts: 21 | I am considering buying the truck listed above. Here is what the guy has listed about it:6 CYLINDER, GRANNY GEAR 4 SPEED, 2 SPEED REAR. RUNS, DRIVES GOOD. SOLID TRUCK ALL ORIGINAL. HAVE EXTRA PARTS. HAVE CAB CORNER PATCH PANELS
The truck looks real good for a work truck, it has the usual cab corner rust but everything else looks pretty good.
He's asking $4500, good price? | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | Sounds like a good price if the tires are good,they are expensive. What part of Tn. are you from?
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | IMO it is rediculously high priced. Depending on an inspection my guess $2500+ -. Not much demand for the larger trucks. | | | | | Joined: Jul 2009 Posts: 21 New Guy | | New Guy Joined: Jul 2009 Posts: 21 | Sounds like a good price if the tires are good,they are expensive. What part of Tn. are you from? I'm from Kingsport, just right up the road from ya. The tires are decent, but they've been on there a long time. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If: No rust. Starts easy and runs/shifts smoothly through all gears in both ranges. Idles smoothly and quietly. All gauges and lights work correctly. Stops quickly and evenly. U-joints and rearend output pinion are not sloppy. Steering feels good and the truck tracks straight. Tires have good tread and no cracking in the rubber.
It might be worth the asking price. | | |
