4 members (walter74, Otto Skorzeny, Ponchogl, Cosmo), 103 guests, and 1 robot.
Topics128,049
Posts1,055,634
#762323 07/14/2011 3:47 AM
I am considering buying the truck listed above. Here is what the guy has listed about it:6 CYLINDER, GRANNY GEAR 4 SPEED, 2 SPEED REAR. RUNS, DRIVES GOOD. SOLID TRUCK ALL ORIGINAL. HAVE EXTRA PARTS. HAVE CAB CORNER PATCH PANELS
The truck looks real good for a work truck, it has the usual cab corner rust but everything else looks pretty good.
He's asking $4500, good price?
scoper27 #762398 07/14/2011 2:26 PM
Sounds like a good price if the tires are good,they are expensive.
What part of Tn. are you from?
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
IMO it is rediculously high priced. Depending on an inspection my guess $2500+ -. Not much demand for the larger trucks.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I'm from Kingsport, just right up the road from ya. The tires are decent, but they've been on there a long time.
scoper27 #762780 07/15/2011 6:05 PM
If:
No rust.
Starts easy and runs/shifts smoothly through all gears in both ranges.
Idles smoothly and quietly.
All gauges and lights work correctly.
Stops quickly and evenly.
U-joints and rearend output pinion are not sloppy.
Steering feels good and the truck tracks straight.
Tires have good tread and no cracking in the rubber.
It might be worth the asking price.
