Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#762313 07/14/2011 3:33 AM
I have a 49 1-ton pickup, I switched the 5.14 to 4.56 The engine sounds like it's screaming at 50 M.P.H. I need to go with a 4.10 or 4.11 I've heard I can get this from a 72 3/4 ton chevy, What other years had this rear end? Thank you. Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
491ton #762354 07/14/2011 10:55 AM
The years are 1967 to 72 with an automatic. IThe ratio you want is 4.10.
1951 1 Ton Completed
Thank you Fred, Now I can start looking. Terry
491ton #762429 07/14/2011 4:37 PM
1 Offline
Correct me if I am wrong but I do believe you are looking for a 4:11 gear set. 37 tooth ring gear, 9 tooth pinion. If you will send me an e-mail address, I will send some pictures of the gearset with Part number and ratio info from one.
It would be 4.10 with the HO52/72. The 4.11 ratio was in the Spicer 70, standard in GMC, optional in Chevrolet, used mainly with the leaf spring option.
Bill Burmeister
1 Offline
Longbox, I beg to differ with you. I have sent you pictures. 4:10 4:11 Eaton Ho52 Eaton Ho 72, Spicer 70 Dana 70 Dana/Spicer 70 , There are differences. One fits 1947 thru 195? 3/4 -1 ton Eaton axels, the other does NOT. Most Eaton 3rd members from a 1967 thru 1972 with an auto tranny fits our 1947 thru 195? rear axels. Dana /Spicers DO NOT! Dana/Spicers are an entire different shape than Eaton. NO WAY you can fit that into an Eaton Axel! The Eaton 4:11 3rd has 37 ring gear teeth and 9 pinion gear teeth. The last time I divided 37 by 9 = 4.111111111111111 ect. Does the Dana/Spicer have 41 ring /10 pinion teeth? that would equal 4:10. To make a Dana /Spicer work , you would have to change out the entire rear axel. Correct me if I am wrong and I will eat6 my words plus my entire rear axel from my 51 chevy 1 ton. Respectfully submitted, Jerry
GM lists it as a 4.10 on the Heritage site specs, all the spec guides show it that way as well. Could be that it really is a 4.11 in both (give or take), and GM listed them as a "4.10" and "4.11" to differantiate between the them in the specs.
Bill Burmeister
