| | | Forums66 Topics128,043 Posts1,055,609 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | I have a 49 1-ton pickup, I switched the 5.14 to 4.56 The engine sounds like it's screaming at 50 M.P.H. I need to go with a 4.10 or 4.11 I've heard I can get this from a 72 3/4 ton chevy, What other years had this rear end? Thank you. Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The years are 1967 to 72 with an automatic. IThe ratio you want is 4.10. | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | Thank you Fred, Now I can start looking. Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Correct me if I am wrong but I do believe you are looking for a 4:11 gear set. 37 tooth ring gear, 9 tooth pinion. If you will send me an e-mail address, I will send some pictures of the gearset with Part number and ratio info from one. Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It would be 4.10 with the HO52/72. The 4.11 ratio was in the Spicer 70, standard in GMC, optional in Chevrolet, used mainly with the leaf spring option.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Longbox, I beg to differ with you. I have sent you pictures. 4:10 4:11 Eaton Ho52 Eaton Ho 72, Spicer 70 Dana 70 Dana/Spicer 70 , There are differences. One fits 1947 thru 195? 3/4 -1 ton Eaton axels, the other does NOT. Most Eaton 3rd members from a 1967 thru 1972 with an auto tranny fits our 1947 thru 195? rear axels. Dana /Spicers DO NOT! Dana/Spicers are an entire different shape than Eaton. NO WAY you can fit that into an Eaton Axel! The Eaton 4:11 3rd has 37 ring gear teeth and 9 pinion gear teeth. The last time I divided 37 by 9 = 4.111111111111111 ect. Does the Dana/Spicer have 41 ring /10 pinion teeth? that would equal 4:10. To make a Dana /Spicer work , you would have to change out the entire rear axel. Correct me if I am wrong and I will eat6 my words plus my entire rear axel from my 51 chevy 1 ton. Respectfully submitted, Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | GM lists it as a 4.10 on the Heritage site specs, all the spec guides show it that way as well. Could be that it really is a 4.11 in both (give or take), and GM listed them as a "4.10" and "4.11" to differantiate between the them in the specs.
