2 members (baldeagle, 1 invisible), 122 guests, and 4 robots.
Topics128,095
Posts1,056,468
Members48,443
#761740 07/12/2011 3:31 PM
It looks to me like the mounts are supposed to be encased in rubber, but the rubber is worn off the exterior. The rubber on the interior is still there, but seems to be a little worn.
Would you replace or re-use these?
Rear motor mount - exterior
Rear motor mount - interior
Does anyone else find their bellhousing to be a dirty mess? There was more crud on the bellhousing than the remainder of the engine.
You've got it apart. Why not just replace it if you can find a new one? Ounce of prevention!
3B Offline
Hy Stove, the mount looks serviceable, as long as the rubber is not all spongy or slimmy, and the two pieces are still held together, hope that helps.
Looks can be deceiving. For good or bad. My personal experience is yes, most bellhousings and especially the mounts are nasty most of the time. I can't count how many times I've had to dig the grease and dirt off to find the bolts and specially the mounts. I'd clean them up real good and if the rubber seems to still be bonded good I'd use them.
If its peace of mind you want and you have the cash then I'd spring for new ones.
On the other hand these are not hard to change if one ever does break.
It boils down to your decision as your the one that can see it.
Riding in the Passing Lane
Its pretty rare that one of those are any good. Even if they are dry the rubber is usually squashed out.
1972 Chevy c10 Cheyenne Super
Before this thread I had no idea there was rubber on the rear mount! Mine's totally all metal! :P
