7 members (Gdads51, Phak1, Joe H, Youngin' Tut 59, Greg_H, carbking, Wayne67vert),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,137 Posts1,056,430 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | It looks to me like the mounts are supposed to be encased in rubber, but the rubber is worn off the exterior. The rubber on the interior is still there, but seems to be a little worn. Would you replace or re-use these? Rear motor mount - exteriorRear motor mount - interiorDoes anyone else find their bellhousing to be a dirty mess? There was more crud on the bellhousing than the remainder of the engine. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | You've got it apart. Why not just replace it if you can find a new one? Ounce of prevention!
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Stove, the mount looks serviceable, as long as the rubber is not all spongy or slimmy, and the two pieces are still held together, hope that helps. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Looks can be deceiving. For good or bad. My personal experience is yes, most bellhousings and especially the mounts are nasty most of the time. I can't count how many times I've had to dig the grease and dirt off to find the bolts and specially the mounts. I'd clean them up real good and if the rubber seems to still be bonded good I'd use them. If its peace of mind you want and you have the cash then I'd spring for new ones. On the other hand these are not hard to change if one ever does break. It boils down to your decision as your the one that can see it. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Its pretty rare that one of those are any good. Even if they are dry the rubber is usually squashed out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Before this thread I had no idea there was rubber on the rear mount! Mine's totally all metal! :P
