0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | I tripped over a 4.10 rear end with a no spin locker in it and bought it. When I got it to the shop I disassembled it to give it a thorough cleaning. Now I'm putting it back together, and I can't figure out a good way to get 85-90 lbs of torque on a 60 lb. Frisbee! I don't want to torque against the pinion gear, that seems like a bad plan, and a good way to chip or break gears... Suggestions? Anyone?
Thanks, Jeremy | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Pick out a ring gear bolt head one or two spaces away from the one you want to torque, and wedge a piece of flat stock between that one and the carrier housing. Use it as an anchor as you tighten the other bolt. Keep rolling the ring gear around one bolt at a time and wedging the one you just tightened until you go all the way around. Jerry
