| | | Forums66 Topics128,142 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 144 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 144 | '51 216 I have the original fan. A new water pump was donated. The heads of the rivets that hold the blades together hold the fan maybe 1/8" away from the face of the pump pulley. I can't remember if this gap was present with the original pump. I turned in the original pump for the core. I thought I had compared the two to make sure they were the same. So, the question is, should there be a gap, or should the diameter of the pump fit inside the fan rivets?
Dave www.fallenherosdreamride.orgall give some MY SON GAVE ALL The fallen hero's dream ride is a 1951 Chevrolet 3100 with original 216 In memory of LCpl Phillip Vinnedge USMC KIA 10/13/2010 Afghanistan
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Original pulleys have a recess to clear each rivet.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I had this same problem. My original also had a stamped pulley that was held on by the bolts and my replacement had a one piece cast pulley. I had to grind little divets where the fan rivets touch. You don't want the fan just resting on the rivets but on the flat face. | | | | | Joined: Jan 2011 Posts: 144 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 144 | Thanks. I didn't think it should be resting on the rivets. Didn't think about just ginding little divets. The rivets hit right on the edge, so it should be pretty simple.
